Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
My iPhone's screen shows messed up colors
At first my phone's screen stopped responding to my touch momentarily, usually hitting the screen against a flat surface and then turning the screen off and on would fix it. But a few weeks ago I hit it and the colors just like broke. The colors were bars, each bar a different color and only a little tiny corner of the screen would work.
Es esta una buena pregunta?
Puntuación 4
1 comentario
Thank-you this should help
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Screen has gone bad. Replacing the front panel will fix the issue.
Guide to replace screen:
Reemplazo de la pantalla de iPhone 6
You can get the screen from here if you do choose to do it yourself:
iPhone 6 Screen
You have a few options, take it to a mobile phone repair shop to get the screen replaced (I would avoid shopping malls as they are generally either expensive or not very well experienced in mobile phone repairs).
Or you can choose to do it yourself which is fairly simple if you follow the steps in the guide well. Parts that you need to be careful in specifically are the metal plate for the screen connectors on the logic board (phillips head screws are different sizes for a reason), removing the home button, metal plate for front panel which has the home button extension cable together and the front camera requires some delicate prying.
Imagen de iPhone 6 Screen
Producto
iPhone 6 Screen
$44.99
Fue útil esta respuesta?
Puntuación 3
in my settings i have a cpu on or cpu off and when i turn cpu on it shows com.android.systemui and a bunch of numbers and colors example 7.39/in red /7.65 in Green / and 8.08 in Blue does anybody know what that is about ?
Puntuación 0
Añadir tu respuesta
adr123 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 45,938
