My laptop cannot power on.
My Alienware laptop cannot power on. No response after pressing power.
Es esta una buena pregunta?
derekseven you want to start off by checking the output of your AC adapter with a multimeter. If the output is correct for your model (you did not tell us which model you have) then you need to consider taking it apart and measure/check the DC in connector. Try and trace the power loss from there on. If you give us your computers model number we may find a more direct answer.
Fue útil esta respuesta?
ive got a similar issue , what model do you have??
cheers
Phil
Same issue with a r2 15 , gtx 980m. It stopped whilr i was gaming and didn t start back. Doesn t turn back on.
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 247
