acer laptop won't connect to wi-fi
i don't know why my acer laptop wireless is not working
Es esta una buena pregunta?
i think update the wireless driver and reset the settings of wireless
Fue útil esta respuesta?
thanks worked for me
How to update if Wi-Fi not connecting,neither Bluetooth tathering,usb tathering.showing IP address failure.
check your device manager.
make sure the device is connected.
try updating the drivers.
i had the same issue i tried everything like reset or update the driver and many more than but nothing just seems to be working with issue . i thought it was the windows and reset the whole computer back to the new settings but still got no success and still having the same issue . now i think i should throw this computer i have no idea what should i do
Hi, What is the model number of your laptop? What OS is installed? Has the WiFi ever worked in your laptop? Have you checked in BIOS to see if there is a WLAN enable/disable option?
i have the same question too . please help
Hi @ecclescolin,
Provide the answers to my comment above and we'll go from there.
OS is windows 10 and i am not sure about computer model
Hi @roberthickman,
On Acer laptops and PCs the model number is written above the serial number on a white label on the the bottom of the laptop or case. if there is none there it is also located in the BIOS area. Press F2 when you first start your laptop/PC to enter BIOS.
hi
1-maybe there is problem in WiFi card
2-maybe WiFi driver
3- maybe it isn’t turn on
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 19
Todo El Tiempo: 3,227
