Saltar al contenido principal
I hear the sound, but with black screen
The T.V was working fine. Then suddenly the screen went black, with the sound still working.
The remote control device is still working too, I can hear volume up and down, and can change channels, The only problem is with the screen.
Es esta una buena pregunta?
Puntuación 8
Agregar un comentario
5 Respuestas
Solución Elegida
mostafafawzy1180 sounds like you have lost your backlight. Could be an inverter issue or a power board problem. Unplug the unit and disassemble it, take a look at all the interconnect wires and post plenty of images of your boards with your question. That way we can see what you see. Use this guide for that.
Fue útil esta respuesta?
Puntuación 3
14 comentarios:
Thank you
I added images to my question
- de
my hitachi flatscreen has no cable so no source of sound. and the screen went totally black. when you press power the standbye button goes off but no picture becomes diplayed.
- de
Mine works fine for a few hours then screen goes black but sound is ok. Anyone know the cause? I live in a cellar could damp b a problem? If i air out the room could that b a soloution? I ask because wen i switch it of for q while it works fine again
- de
@oldturkey03 and @darsh1180
The pictures were posted, where's the answer?
- de
@greatoak bad power board. What is your question?
- de
Mostrar 9 comentarios más
Try turning off the dynamic contrast in the picture settings. Should be under advanced settings.
Puntuación 0
1 comentario:
Considering I have a very very dark screen it was really challenging to make this change - I had to do it in a pitch black room - however it made no difference unforuantely.
- de
My Hitachi 50 inch TV screen slowly going dark sometimes it gose off but it dose stay on what do I do!
Puntuación 0
i have an hitachi flat screen everytime i turn it on it makes some weird noise and screen stays black what should i do to fix it?
Puntuación 0
When I turn on the TV by remote. It shows. PLEASE WAIT but then no picture.. doesn't that mean the display is working?
Puntuación 0
Añadir tu respuesta
mostafafawzy1180 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 48
Todo El Tiempo: 73,731
