Saltar al contenido principal
El smartphone Android de 5ª generación basado en Android de Samsung fue lanzado el 11 de abril de 2014. Las mejoras en el teléfono incluyen un escáner de huellas dactilares, cámara actualizada, pantalla más grande y resistencia al agua. Está disponible en cuatro colores diferentes; Negro, azul, blanco y cobre.
Preguntas 577 Ver todo
sm-g901f screen same as all other models?
Is the lcd/digitizer assembly the same across all GS5 models?
I have a sm-g901f just wondering can i get a screen the is being sold as for the SM-G900F and will it be compatible
thanks a lot
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
5 Respuestas
Solución Elegida
Yes, all variants of the Samsung Galaxy S5 model use the same LCD. Except for the smaller and larger sized one of course.
Edit: Did a image check on both LCD's. They both have corresponding numbers and etc on the ribbon connector on the LCD ribbon cables themselves.
Edit: For SM-G901 phones you will have to use the same model of screen or it will bootloop. Sm-g900 series don't work.
Fue útil esta respuesta?
Puntuación 5
9 comentarios:
Ben,
Are you sure about that?
- de
Yes. Because if you buy the screen with frame pre-assembled together it will not fit all normal s5 models as some s5 logic board have different board layout in terms of components on it.
But if you get screen without frame. It will work on all SM-G90xx models.
- de
Hi, this can't be true as I have 2 G901F phones sat in front of me and I have tried 2 G900F screens on them both and never work, they just boot loop. If I start the phones without the screen attached they both start up perfectly. Yet trying to get hold of a G901F LCD is a nightmare!!
- de
Thanks for bringing that up. I'll update my answer.
- de
Hi So all the G900 screens do not work?? but I cannot seem to find any G901 screens on sale. Anyone can help??
- de
Mostrar 4 comentarios más
You ABSOLUTELY need a specific G901F LCD !
You can order it here ; https://www.ebay.fr/itm/183173477341
Any other LCD will give you an infinite bootloop.
Alain
Puntuación 1
I Wonder if the QHD 2k screen of the galaxy S5 LTE-A g906 fit and work on the S5 PLUS g901f. . They have the same Snapdragon processor. I have a g901f and i want to upgrade the screen resolution.
Puntuación 0
Would a g900f lcd screen fit a g903f as the display screen is the same
Puntuación 0
1 comentario:
This is the combination I need to fit. Anyone know the answer?
- de
I wonder if you can Flash G900 LCD for the G901F model ?
Puntuación 0
Añadir tu respuesta
rcast estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 7,364
