Saltar al contenido principal
Los auriculares Beats Solo 2 Wireless son una versión inalámbrica de Beats Solo 2. Lanzados en 2014. Número de modelo: MHNG2AM/A.
Preguntas 48 Ver todo
Why are my beats only paring up and working while charging?
The beats will only work if they are connected to a power source, the Aux cable works perfect, but whenever i want to try the wireless mode it wont work, for example :
If the beats are being charge and i pair my iPhone it works and everything,but if I unplugged them from the charger it wont even turn on the Bluetooth
Es esta una buena pregunta?
Puntuación 3
4 comentarios
I have Zedd solo doing the same thing
- de
I have a Polaroid doing the same thing
- de
This gonna sound weird but open the beats on the side that has the lights then close them back up and then charge it worked for me hope this helps
- de
Cam dynasty if you see this you are a true legend
- de
Agregar un comentario
5 Respuestas
Solución Elegida
Two problems I would investigate:
1. is the internal battery dead?
2. loose connections with respect to the internal psu/battery
try opening one of the speakers - the side with the charger port. take a look at these images for some guidance
Fue útil esta respuesta?
Puntuación 9
3 comentarios:
Excuse me, but which pictures ??
- de
Ah sorry about that: Here are some links I just found
some of these images and articles are not specific to your edition but all speakers are constructed the same way, especially regarding power input and battery placement relative to speaker element (because of electrical noise from AC-DC-AC conversion and effects of relative distance and placement of electronics components on creating issues with use or the need for additional noise-reducing systems (which as you know, more things to subdue the symptoms could just mean more isolated malfunctions and harder to fix as there's no part to swap, when the entire system is degrading.)
let me know how it goes!
http://www.core77.com/posts/52314/A-Look...
http://www.head-fi.org/t/632063/dre-beat...
http://www.head-fi.org/t/688434/my-old-s...
http://gizmodo.com/are-beats-headphones-...
- de
please solved my problem.When I plugged it can be work.When I unpluggedit can't be work.
- de
I have this problem just like when I plugged than it can be work.When I unplugged it can't be work.
Puntuación 3
My only works when it’s charging but when it is not charging it doesn’t even turn when battery is 100 percent and I got them today
Puntuación 0
Unfortunately, this also applies to me. My Bluetooth headphones only turns on /connects to my iPhone when the headphones is charging. If I disconnect the charger from my headphones, it will turn off automatically. WTF?! Why this happens? I never have this problem before. This REALLY REALLY REALLY ticks me off. Someone better have a better explanation for this.
Puntuación 0
1 comentario:
Mine are doing the same thing. Mine are the wireless beats and I haven't had them a year
- de
Super weird, had this same issue. I’ve had mine for a while now and I use them for probably 2-4 hours a day, whether it being at the gym, doing yard work, or even running in the rain lol.. yesterday it was drizzling outside and I was having a football catch outside with them on. I went inside and they wouldn’t work right, and wouldn’t turn on at all unless plugged in with the charger.. I tried basically all the methods and nothing worked for resetting them, so I just simply tried using an aux wire instead (3.5mm jack) and they worked fine after! They turn on flawlessly and connect wirelessly with ease. Hope this helps!
Puntuación 0
Añadir tu respuesta
briantrevino estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 77
Ultimos 30 días: 356
Todo El Tiempo: 32,204
