The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
Preguntas 94 Ver todo
78 mercedes 280E 2.6 m110 I6: difficulties running in the morning
When starting in the mornings will start up fine and idle rough for a 10-15 minutes and during that time acts like the engine is flooding if you try give it gas. What's going on?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
The CIS system on the M110 engine uses a separate electronically controlled cold-start valve. It is basically one single fuel injector that sprays into manifold, enriching mixture. Device is controlled by a thermo time switch, which turns on power to the injector. If the injector leaks or runs too long, and overly rich condition exists causing poor idling and greater fuel consumption (poor mileage). Check thermo time switch by unplugging electrical connection at cold-start valve. If rough idle condition persists when power is disconnected, injector is likely leaking or spray pattern is diminished (caused by a dirty nozzle). It is more likely the injector is faulty than a fault of thermo time switch exists.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Paul severance estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 97
