Saltar al contenido principal
La Brother MFC-240C es una impresora de inyección de tinta a color todo en uno.
Preguntas 29 Ver todo
How so I find out about Troubleshooting for message Print Unable 50?
I had a paper jam. After clearing out the paper, I am getting a message that says Print Unable 50- Refer to Troubleshooting chapter in Owner's Manual. I cannot find my Manual. Can you tell me what to do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
4 comentarios
print paper in blank
- de
troubleshooting for massage print unable 50
- de
how so i find about troubleshooting for massage print unable 50 ?
- de
troubleshooting for massage print unable error 48 mfc j 200
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Here is a link to the User Guide for your printer.
https://www.brother-usa.com/modeldocumen...
Found this information which may (stress only may) be the cause of your error message:
This error is usually caused by the Carriage Encoder Strip being dislodged from the sensor mounted on the Print Head/Carriage Assembly. The upper case assembly will need to be opened, and the encoder strip will need to be put back into place. Its also possible that the error can also be caused by grease or fingerprints on the Encoder Strip, even if it is still in place
Here is a link to the service manual for your printer (as well as other similar Brother printers). Scroll to Ch.6-48 for information regarding the CR encoder strip.
http://ftp.brother.co.il/fax/MFC845.pdf
If it is all a bit daunting, suggest you either contact Brother service or a professional printer repair service and ask for a quote.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Louise Parker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 4,527
