Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
Preguntas 2948 Ver todo
4s screen Black and white, fuzzy after change
I changed my cracked screen with a replacement from ebay I got for 20 bucks aud. Everything including touch works fine except for the display. This is what I get:
http://imgur.com/RL7flsu
Is this more likely a faulty lcd or something I've done?
The dimming you see in the picture is not a camera effect. Thats how it looks.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Did you take OFF the new screen protective sheet on the back of the LCD? If you installed the screen correctly and perfectly, then you need a new screen.
Fue útil esta respuesta?
Calificación 0
This can be faulty lcd or you damaged when were replacing... check the connectors.
I will recommend you before replace the new lcd, test it please and connect with out removing old lcd.
Calificación 0
Añadir tu respuesta
Simon Di Bella estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 51
