Saltar al contenido principal
Repair and disassembly guides for Magellan GPS devices.
Preguntas 67 Ver todo
My Magellan GPS 9250T-LMB wont come on
I was on the road, my GPS was working. I unplugged the power cord from the car outlet. 5 minutes later, I plugged it back in, but my GPS won't come on. To check if the cord got bad, I checked another cord, but the GPS won't come on. I opened the GPS and checked the voltage of the battery. It shows 3.7 volts. Please tell me your opinion on the problem. Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
3 comentarios:
Hi,
Have you tried resetting your GPS?
To Reset: Slide the power switch all the way over to the left and hold for 5 seconds. Release then try to turn on your GPS
- de
es i tried slide power switch to the left like you set, but it still it not come on
- de
I have the same problem and the reset did not work!
The light that shows it is plugged in to power is the only thing that works at all. How can I make it come on again?
- de
Agregar un comentario
1 Respuesta
Charge your GPS overnight take a paperclip pushing the reset button hold it for 8 seconds release it hold the power button for 8 seconds then release it that should make it come back on if it does not you need to replace the battery.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
roleg1313 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,220
