Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Pregunta Cerrada
Boot loop - Missing SMD? Need help identifying.
Hey there, I recently replaced a screen on an iPhone 5c, and it looks like I might have knocked a component from the board while disconnecting the battery. Can anyone tell me what this is? It's the top-most resistor or capacitor next to the battery terminal if you're looking at the phone upright.
Es esta una buena pregunta?
Puntuación 0
2 comentarios
garret, sorry but that is way to vague to make any proper identification. Attach an image and mark the missing component with your question. For that you can use this guide
Agregar imágenes a una pregunta existente
- de
Thanks for the tip, I added the photo
- de
Agregar un comentario
1 Respuesta
Solución Elegida
garret, that is FL11 which is a 120 Ohm 210mA filter in a 01005 package. Without this filter the system cannot read the battery status so it will keep powering down. This is the smallest package available and will require some good tools and excellent soldering skills to be replaced. Do a search by MMZ0402S121C to find a replacement. Buy multiples cause it's a bear to solder:-)
Fue útil esta respuesta?
Puntuación 2
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 589
