Steering gears loosen up
I own a Craftsman Lawn Tractor model 917.25022 with tight turn. The mower steering stops working in either direction. The small gear on the end of the steering shaft stops meshing with the flat gear underneath. A bolt loosens up that holds the flat gear. You can tighten the dickens out of it and it will steer for awhile and then it happens all over again. I had a contractor who does lawn mower service for Sears check it and he just tightened it up to get me by till the warranty expired. Does anyone know of a fix to stop this problem?
Es esta una buena pregunta?
