Saltar al contenido principal
Guías de reparación y soporte para tu televisor LG.
Preguntas 1345 Ver todo
LG 60PZ950 no image but sound ok
I have a TV LG 60PZ950 (march 2011)
The color started given out but now hardly any image is visible but the sound is ok.
How can I fix it? or what part to change?
this is the image we see
the board pictures
Es esta una buena pregunta?
Puntuación 2
4 comentarios
Cindy, can you elaborate on this "color started given out"? Do they look faded or just very dark image altogether?
- de
Dark image all together
- de
Sounds like your backlight is going out but it is hard to tell without actually seeing it. any chance you can post some images of what you see.? Agregar imágenes a una pregunta existente A dark picture can be caused by a bad Z-sus board If you can post some images of all of your boards. For that you will have to take the back off.
- de
Sorry about the delay, we moved and got really busy. I have added the pictures you asked.
Please let me know if you need anything else
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Cindy, thank you for the pictures. Yes as previously suggested this could be caused by the Z-sus Board. I attached an image of where to check and what to check for. You will need a multimeter for that.
The board itself is available at places like this. If you are handy with a soldering iron, you can also try and replace the transistors on the board itself. Those are FGPF4633 IGBT's and are available at Mouser.com or you can buy a repair kit from here.
Fue útil esta respuesta?
Puntuación 1
i removed all the boards and resoldered, then applied a heat gun on every board and it worked.... now i have all HDMI ports working, and no issues with colour
Puntuación 0
what is the cost for the part?
Puntuación 0
1 comentario:
Debbie Freeman what parts and it will depend on where you are located.
- de
Añadir tu respuesta
Cindy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 2,192
