The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
Preguntas 3579 Ver todo
water damage corroded resistor iPhone 5s
I dropped my phone in the sea, i cleaned it with iso alcohol and it came to life but no screen, it connects to pc fine, i removed the shield from the logic board and found alot of corrosion, i cleaned best i could and a resistor fell off, it was the only resistor with corrosion so i am wondering if i can fix this myself, also i have damaged a plastic part with the letter 'L' it has copper wire inside
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
felony01, the "plastic part with the letter 'L'" as well as the other part are both coils (inductors). The "plastic" one is L3 which is a 22UH-20%-0.38A-0.876OHM VLF302510T-SM coil. L19 is a 1.5UH 1.6A 0.13OHM MAKK2016 inductor.
Fue útil esta respuesta?
Calificación 3
Comentarios:
oldturkey03, Thanks for the reply, do you know where i can purchase them?
can i use circuit breaker instead?
por
I'd try Digikey.com or Mouser.com. No, you can't substitute for those.
por
Añadir tu respuesta
felony01 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 231
