Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Backlight problem on 5s
I think I need to replace the backlight filters. I've read plenty about where they are on the iPhone 5 but can't find anything on the iPhone 5s. Can anyone tell me where they are on the board and where I can buy them? Is this all I will need to replace or should I also replace the coil and ic chip.
Thank you in advance!!
Es esta una buena pregunta?
Puntuación 2
1 comentario
You have micro soldering skills and tools?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
I'd check around FL24, FL25, FL26 as well as the capacitors C17, C243 and C18.
further explanation package size
Fue útil esta respuesta?
Puntuación 7
11 comentarios:
Thank you! This was exactly what I was looking for. Do you know where I can buy the filters and capacitors?
- de
Looks like they are all in stock a digikey.com
- de
Thanks oldturkey03. Is this the part for the filter? FILTER CHIP 120 OHM 3A 0603
- de
Found it (I think) - FERRITE CHIP 220 OHMS 2.0A 0603
- de
susan, the three filters are 240 OHM 0.2A 0.8 OHM in a 0201 (0603 metric) package. Available at places like this http://www.digikey.com/product-detail/en...
- de
Mostrar 6 comentarios más
Probably not the cheapest solution, but perhaps consider replacing the entire display assembly, digitizer en all. It's a Much Much easier job.
Puntuación 0
1 comentario:
I already tried that. I can see the apple logo, barely, using a flashlight pointed at the display, so I think the backlight filter is blown. I'm up for replacing it/them. Can solder, just don't know where they're located. Plenty of info on the iPhone5, not much on the 5s.
Thanks!
- de
Añadir tu respuesta
susan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 2,316
