What do I do if the battery explodes?
After use, the device battery has puffed up like a bag of popcorn, and I am unsure if it can be repaired or will need to be replaced.
Es esta una buena pregunta?
Exploding battery is a common problem associated with the device. If you notice bulging in the back of the device indicating the battery has expanded, or the battery has exploded entirely it is necessary to replace the battery for continued use. See Battery Replacement Guide for replacement instructions.
Fue útil esta respuesta?
If its just the battery it can be replace with the mother board. My friend took out the battery an replaced it with a new mother board and battery it works just fine now
Teishka Candelario why would you suggest to replace the motherboard? The device definitely needs a new battery but not sure why you think it would need a motherboard.
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 1,467
1 comentario
Take the battery out
- de JaydenGill
