Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
After noticing your battery life deteriorate or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
  1. 1. Back Cover
  2. 2. Battery
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. Remove back cover with lever tool, exposing the battery and motherboard. Remove back cover with lever tool, exposing the battery and motherboard. Remove back cover with lever tool, exposing the battery and motherboard.
    • Remove back cover with lever tool, exposing the battery and motherboard.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the two black tape strips from the battery pack. Remove the two black tape strips from the battery pack. Remove the two black tape strips from the battery pack.
    • Remove the two black tape strips from the battery pack.
  5. Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers. Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers. Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
    • Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
  6. Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
  7. The new wires must be soldered back into place on the motherboard at the original location. For tips on soldering techniques, see this Soldering Guide For tips on soldering techniques, see this Soldering Guide
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide
Conclusión
Una persona más ha completado esta guía.
Justin
Miembro Desde 29/01/15
407 Reputación
2 Guías creadas
Equipo
Clemson, Team 14-4, Shirley Spring 2015 Miembro de Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,038
