Saltar al contenido principal
Modelo A1237 o A1304 / 1.6, procesador 1.8, 1.86 o 2.13 GHz Core 2 Duo
Preguntas 312 Ver todo
External access of MBA HD
I have an HD pulled from a broken up MacBookAir. It uses a special ribbon cable to connect to the LB (?). What can i use to access the data on this drive now that it is out of the laptop. Thanks.
Update
Found the solution here:
http://www.digitalintelligence.com/produ...
If the link doesn't work directly, it's hard to find on the website.
Es esta una buena pregunta?
Puntuación 1
1 comentario
I think LB means Logic Board incase anyone was as confused as I was.
- de
Agregar un comentario
8 Respuestas
Solución Elegida
1.8" SATA-LIF enclosure:
http://www.memoryc.com/products/descript...
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
Just for the record: The drive is an ATA (IDE) drive and uses a (semi)standard ZIF (Zero Insertion Force) socket. The usual adapters won't do the job.
Puntuación 2
1 comentario:
Absolutely correct!
- de
Buy an enclosure and put the drive in there. Then you can connect it to any computer with USB, firewire, or whatever type enclosure you purchase.
Puntuación 0
1 comentario:
Solution found. See addition to original post.
- de
do you want to permanently use the hard drive as an external drive? if so, then yes as rab777hp said just get a drive enclosure to convert it to an external drive
however, if you only need to temporarily access it externally (e.g. you will later re-install it in some computer), there's a more flexible alternative.
get yourself a Newertech USB 2.0 Universal Drive Adapter, or similar product from another manufacturer. This will let you attach any ATA or SATA drive, 2.5" or 3.5", hard drive or optical drive - via USB to your computer. it's a very handy adapter to have around when you're swapping or cloning drives. But as I say, this is only for temporary use, it's not meant to replace an external drive enclosure.
Puntuación 0
1 comentario:
This drive is smaller than 2.5. The connector is not standard S/ATA. Its more like the HD in an iPod. It would have to be a tiny ribbon cable. Have various enclosures plus the Newertech device. This HD will not interface directly to any of these enclosures. Thanks.
- de
The MacBook Air that I have contains a Samsung HS12UHE
Which has a SATA interface with a 24 pin LIF connector.
I contacted the support for the Digital Intelligence ZIF Enclosure and not only will this NOT work but they do not have a device that will work with this drive.
If anyone has found an adapter that works with this drive please update this question.
Puntuación 0
I need an adapter as well.
This one here will not work: http://www.adaptare.de/blog/adapter-fur-...
They tell me in the forum that the MacBook Air is the only computer that uses SATA-ZIF at the moment.
Please let us know if someone finds an adapter for SATA-ZIF.
Puntuación 0
As i stated way above, the enclosure i bought from Digital Intelligence DID work for me. The LIF connector was actually a "VHIF" connector, but it did work.
Bought this one recently
<http://www.amazon.com/gp/product/B001OYC...>
from Amazon.com and it, too, worked on the model of MacBook Air that i had at the time. It was a LIF connection.
---Danno
"May your Mac(s) always start up!"
Puntuación 0
Does anyone know if the cubeternet enclosure works on zif-24?
Samir
Puntuación 0
Añadir tu respuesta
Danno estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 5,615
