Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
Es esta una buena pregunta?
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
Fue útil esta respuesta?
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
Where do i purchase a new battery?
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 4,968
