Saltar al contenido principal
proximity sensor not working aftet screen replacement
Just replaced a screen on a lumia 625. But the screen turns black when making calls. When I lift the screen away from the sensor, it shows again. Is there anything I can use whuch could strio the purple paint (or whatever it is) away from the glass where the proximity sensor lays?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Did you use original foam tape to adhere the digitizer? Or double sided tape? I've had the same thing happen to me on my first lumia 625 job, using self cut double sided tape. Since then i always have original pre-cut foam tape in stock. Not had a problem ever since. the sensor is very picky.
Fue útil esta respuesta?
Puntuación 3
If I remove some of the foam tape thats on the screen, will this fix the problem?
Puntuación 0
Añadir tu respuesta
Duane estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 19
Todo El Tiempo: 2,671
