Saltar al contenido principal
La versión mejorada de Nintendo de Nintendo 3DS. Cuenta con pantallas más grandes, mayor duración de la batería, mejor densidad de píxeles y un mejor diseño.
Preguntas 411 Ver todo
My 3DS XL has a block in the headphone port
When I were using my 3DS XL with headphones, the headphones broke and a piece got stuck in the headphone port. It means that I can only use headphones with a part removed. Here's what they look. (you can't see the block that's stuck there) What I can do to remove it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I'd say, first try using a pair of tweezers to reach inside the headphone port and pull out the broken-off part.
If it can't be tugged out, I would consider opening the device following this guide until I could get to the headphone jack, and then trying to either push the broken part out if there's an opening in the back of the headphone jack, or to perhaps get the contacts inside the jack to push less firmly on the broken-off part to make pulling it out with tweasers more feasible.
If that didn't work, I'd probably resort to unsoldering and replacing the jack, but if you don't feel comfortable with soldering you might or might not want to try that.
I'm no expert; anyone else have a better idea?
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
[deleted] estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 2,213
