The fan blades won't spin--how to fix?
I can hear the motor whirring inside when I first turn it on but it takes awhile for the fan blades to actually start spinning. How can I fix this?
Es esta una buena pregunta?
The fan blades could be damaged. You can replace the blades, or see if there is anything blocking their movement. There could also be a problem with the motor as a whole. Use this guide to check the fan blades and replace the motor.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 50
Todo El Tiempo: 12,522
