Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
I phone 5s stays on white apple logo and random blue screen
i did a screen replacement on an iphone 5s that has a broken lcd. i changed it and now i phone 5s stays on white apple logo and random blue screen pops up.
It is not the proximity flex as i have already changed that. i also changed the battery but still nothing. I also tried a different lcd but still nothing different.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
i dropped my iphone 5s and now the screen goes from black to dark blue with either a blue line or a redline a brought it to metro they said I broke the LCD I really need it fixed when I brought they said it wasn't turning on but I turned it on at home and it was when I say turn on I mean it goes from almost turning on to blue.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hello I'm afraid the motherboard is damaged there are four screws on the emi shield that cover the lcd connectors the top left and top right screws will be long screws the bottom left and right should be small screws.
Go and check I bet you have a long screw in one one the bottom screw holes..
A long screw in the bottom screw holes will accually screw through traces on the motherboard
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
i always put the screws in the right place, it's possible it got damaged when it was dropped. the lcd was damaged but glass was perfect
- de
Did u ever find the problem?
- de
Have you actually checked for markings where con has suggested the damage might be?
I always use a magnetic mat and put the screws in the exact same patteren as they come off, even on the 4/4s which I've done many and can tell which screws go where now, very easy to become complacent. Again, just check the board where the screws would have gone.
Puntuación 1
Well that's the reason for a blue screen when screws arnt put in proper place
Puntuación 0
Añadir tu respuesta
Subba estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 315
