phone was coming on and off when charger plugged in.
My phone just stopped charging. The charger, when plugged in was coming on and off.
Es esta una buena pregunta?
Hi,
- Try with another battery
- Try with another charger (not with the laptop USB)
- Clean the battery connectors on the phone
- Try to charge the battery externally
If you phone switch-on normally with other battery but again have a problem with the charging, then you have a hardware problem. This can be broken USB connector, charging line on the mother board or charging i.c.
If you phone can't switch-on, try to enter in the Android Recovery menu and reset it, or try to flash it with Odin. But if you phone can't enter in the recovery mode (Home + Volume Up + Power) or Download mode (Volume Down + Power) you have a hardware problem with the mother board. For this operation you must use a fully charged battery.
Regards.
Fue útil esta respuesta?
please Guys I have Sony ST21i with me ,each time I try to charge the phone it went off........I need a help
Most of the times problem occurs because of faulty charging connector. So change the connector and see if it helps.
my phone is a coolpad and evey time i put any charger it wont work is my battery damage
and it turns off and on
My phone was on the charger and it was going on and off and when I wake up in the morning my phone is on 2% what do I do?
This sounds like you have a bad charge port. It’s possible it’s the battery but most likely, it’s the charge port. As with any electrical component on a phone, they can just fail. It’s also possible that at some point in time, there has been physical damage done to the charging port. Does the charge cable feel snug in the port? If it feels loose there could be something in the charge port that is causing you to have a poor connection. You can try and clean out the charge port with a toothbrush or a small pair of tweezers. Just be careful when you do this. If you have the ability, I would also try a new battery and see if that makes a difference. Before you go though the hassle however, have you tried a different cable with a different power brick?
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 25
Todo El Tiempo: 21,967
I hade the same problem.. when i plugged it.. it stil charge but 2 seconds later the charge goes out and 2 seconds later the charge come in.. is my phone damaged?.. can anyone help me? I really-really need your help..
- de Roland Stephen
