The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
Preguntas 37 Ver todo
Why is my Nook HD's screen unresponsive?
My screen is on, but displays nothing or is unresponsive to touch.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 11
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Frank Poole, I am wondering if it is the same Nook HD from your Why does my Nook HD's screen have frozen pixels or black lines? There is the possibility that you will need a new display, check your other question for the how to etc., If it is a different one, you may want to try a Factory Reset and see if that will help. "Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. From here. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 2
In addition to oldturkey03's advice I recommend checking out the nook HD troubleshooting page: Nook HD Troubleshooting.
Calificación 1
Don't do a factory reset til uve backed everything up or moved it to an external sd card! U will lose everything! Mine has this same issue. The battery would start to heat up, which I've read happens frequently with nooks, & becomes unresponsive/freezes. I just shut it down, wait about 15 min or so til it cools down. When its turned back on its fine.
Calificación 0
Añadir tu respuesta
Frank Poole estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 21
Últimos 30 Días: 69
Todo El Tiempo: 7,000
