Saltar al contenido principal
Most likely cause of digitizer problem after water damage
Last weekend, my wife took my 3 year old daughter to a friend's birthday pool party. My wife ended up jumping in the pool to save a kid and had her phone in her pocket (iphone 5). I had her put it in rice until I was able to take it apart. I cleaned all the connections with 91% isoproply alcohol, dried it with a hair drier then let it sit over night. I put it back together the following day (Sunday) and it worked, except for he vibration mech. I had to go on travel on Tuesday and literally, a hour after i left the digitizer stopped working. It's not Saturday, I took it back apart, thinking the connection needed to be cleaner of the cable reseated, but neither seems to be working. I haven't replaced the battery, but I know I should do that. Anything I should try before buying a new front assembly? Thanks!
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
8 Respuestas
Solución Elegida
"Clean the connections" doesn't count as cleaning the phone. Just tonight I put a phone through the ultrasonic cleaner, then scrubbed the part of the board that is visible. I desoldered the EMI shields to see how good the result was----there was still frank corrosion in a couple of spots.
In my book, an iPhone 5 water damage recovery requires desoldering the shields and scrubbing every inch of the board, and then replacing any component that is corroded, burned, or damaged after examination under the microscope. Think of corrosion as a cancer that will metastasize if left unchecked.
When you say 'digitizer not working' do you mean the display, or just the touchscreen function. If you mean the display, I would guess that your backlight coil or filters have failed---very common after water damage. Of course it is also common for the LCD to fail as well. If I were you, I would give it to a local shop and ask if they desolder the shields to do a full water damage recovery.
jessa
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
Hi jessabethany have u a email?
- de
Thanks for the response. The touchscreen function is what's not working and what stopped working. The LCD is fine.
Are the shields on the logic board? How does one find a local shop that does this sort of thing? I watched a couple videos of removal of the shields... do you put the shields back on afterwards?
I have an iphone5 as well. To check if the problem is with the display assembly, I'm considering putting my display assembly on my wife's phone to see if it works. Any issues with doing this?
- de
No problem putting the new assembly on your iphone for testing. I would be sure to disconnect battery first, then reconnect it last.
I would call your local shops to see if they desolder the shields, if you can't find one, feel free to contact me for mail in via my profile
I don't usually put the shields back on after--they are 'bumpy' after removal and not essential
- de
Water damage is so tough to diagnose you could clean it and all is working grand then it just decides to die..
Puntuación 1
2 comentarios:
con - double click on jessabethany icon to get to her biography and email address.
- de
Cheers Mayer
- de
This has worked for me numerous times...Submerge your device in 70% plain rubbing alcohol for 10-15 sec. This will dissipate any remaining water and residue without having to further dismantle your device. REMOVE THE BATTERY, SIM AND SD CARDS FIRST!!! DO NOT USE 90% ALCOHOL. Allow the alcohol to fully dissipate before attempting to turn on your device get a new battery and rejoice!
Because alcohol evaporates quickly this will not harm any components when you submerge your device. I have had much success with this in my 20+ years as a tech.
The rice and silica are good alternatives but don't fully complete the required steps to get your device running again and if it does it's usually short lived.
Puntuación 1
when your phone get wet don't ever turn it on because it will short circuit... you should take out everything removable parts like battery, sim card, memory card and wipe everything dry... now you need to extract all the remaining water... there are 3 ways to extract the remaining water, one is by rice bag method.. put your phone in a not cook rice bag then leave it for 72hrs... two is by silica gel bag method... put silica gel with your phone in a zip lock bag and it will dry your phone in 2-3days... the third method is using Bhesstie bag.. the air tight pouch contain moist absorbing beans... then like the first two method just put your phone inside the bag and leave it for 24-72 hrs... it will absorb the remaining water in your gadgets.. whatever method you use after doing it just put together your phone and hit the power button... it will work just the way it used too... this 3 methods works and proven... just try it before buying a replacement... thanks
Puntuación 0
Ulysses no offence but this will not help any phone water needs to be washed off not dryed or absorbed by rice or gel bags. In almost all cases there will be corrosion and this needs washed off to prevent further damage..
If by any change people can't get motherboard washed then your method is the next best thing but is only a quick maybe fix not a solution
Puntuación 0
I put the phone in 91% alcohol and then used a blow dryer. I put it back together and put it on the charger when I turned it on the touch screen didn't work. Any ideas what I can do to fix it?
Puntuación 0
1 comentario:
Karen, I think what you messed up with was 91% alcohaul. 91 doesn't dry as fast and using a blow dryer only spreads the most even further into the device therefore causing all functions to work improperly. I would suggest using 70% alcohaul so that way this won't occur. Also don't use a blow dryer. My sister did that to her phone after she had dropped it in the toilet and she broke it even further by using the blow dryer.
- de
Could someone please go into depth regarding this recommendation that a lower concentration of alchol is better(i.e. 70% is better than 90%). I just as soon use Everclear and avoid the isopropyl residue, is this a bad conclusion?
Puntuación 0
I’m not sure why people are suggesting using 70% isopropanol is better than 91% isopropanol. Electronics grade isopropanol is ~99.8%. The higher the better for getting rid of water. I use it in my lab everyday and it evaporates very quickly.
Puntuación 0
1 comentario:
My samsung A5 2017 was dropped in water during shower although its ip68 water proofing but don't know it didn't work as I start having touch problem after 1 to 2 hours and than I barely able to turn it off from screen and than put it in uncooked rice bag of 50 kg I don't know what to do now plz suggest some thing
- de
Añadir tu respuesta
Matt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 41,253
