Saltar al contenido principal
Guías de reparación y desmontaje de enrutadores AirPort, incluidos Airport Base Station, Airport Extreme y Airport Express. La línea Airport se introdujo en julio de 1999 y se suspendió en abril de 2018.
Preguntas 96 Ver todo
No power and no internet access
Any way to repair an Airport Extreme Base Station with Gigabit Ethernet?
One day the front light went out and no internet access.
Used the power supply from my other Airport but it still would not power up.
Thanks!
Es esta una buena pregunta?
Puntuación 1
1 comentario
I have this exact same problem. It was working fine one minute and then stopped working the next. I am taking it back to the Apple store to have them check it out. Mine also had a bit of that electrical burning smell coming from the device. When it is plugged in I can hear it emitting a high pitched humming type sound. Probably some internal component failure. Will see what they can do.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I've seen no user replaceable parts in either the power supply or the unit. If you get no lights on the unit you can try replacing just the power adapter. If you have AppleCare on your computer the Airport Station will be covered by Apple.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Añadir tu respuesta
Eric Townsend estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 3,812
