How do I repair my frothing disc?
How do I repair the frothing disc so it froths milk product again.
Es esta una buena pregunta?
Has anyone figured out how to actually fix this problem? Mine started working again for a day or two and then today it went back to not working again. I guess every 6 months its time to buy a new one?? If that’s the case I think I will look for a different company to buy one from as this should last longer then 6-8 months. WOW!!
Fue útil esta respuesta?
I have the same problem; I always keep it clean. Anyone have a fix besides buying a new one?
Same here!! I bought it a year ago and it stopped working a few months ago. Amazon sent a replacement. I read through the use manual and it said I hadn’t to unplug it after each use and should NOT scrub hard or else it would peel off. Ever since I’ve been doing so. Again it stopped frothing! It’s quite pricy and should last longer!!
I just want to take the thing apart... Two screws on the bottom do not seem to fully release the top from bottom. Mine seems to be showing some resistance and maybe an internal cleaning and oil job will get the inner magnet to start spinning again.
Anyone get this thing apart?
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 3,097
Keep it clean as oils build up. Take it out and keep both cup and disk very scrubbed and it will work again. Also make certain your burrow is working properly and the disk is actually spinning before you leave it .
- de Linda Childs
I recently started having the same problem with mine. It heats up but the little disk that you put into the cup to get the milk whipped will not spin. I’m not sure what it means to take the disc out and clean. Does that mean the disc in the cup? Because I always clean that. Or meaning the appliance itself. I didn’t realize that came out of the appliance if that’s the case. I’ll have to check that out. I’ve had it less then a year so I was quite surprised when it stopped spinning. Was anyone able to fix it?
- de Lena
Yes, I found you have to remove the disk and wash it well and also wash the cup well as it can collect oils under the disk. This works for awhile. But, after three years I had to replace it and three years before that I had another one. That's it!
- de Linda Childs
