Do I need glue/adhesive to replace only glass at iPhone5? Which?
Hello community,
(sorry for mistakes, english is not my first language but i hope you understand)
a friend of mine broke the glass of his iPhone 5 and asked me to replace it (only the glass). I watched a few tutorials in the internet where some people show how to separate the glass and the display and put a new glass on the display. I saw that they used a 70% oder 90% alcohol disinfection.
What i couldn't find is which type of glue/adhesive the used and where to buy it in the EU.
I would like to know if it is possible to put it all together and leaving out the glue. Would that work???
Thank you for your answers.
Es esta una buena pregunta?
4 comentarios
I think what i really meant was: Do i need an liquid glue or can i use tape and if i use tape can i only do it on places where not the LCD is.
PLEASE HELP
- de myname
Hello together again, i did repair the iPhone 5 of my friend.
The only thing which was a little complicated (took most of the time) was removing the broken glass and the rest of the glue. And you really DON'T NEED GLUE to apply the new glass. I just screwed the display to the new glass WITHOUT GLUE and it is working very well.
At the two upper edges of the display there was a little bit harder glue which won't get soft if you heat it up but i took a razor blade and carefully removed it.
I used the glue instead for putting the glass and the upper frame together and to fix some things on the new glass.
Everything is now working very well.
So it is not true that you need to put the glass and the display together with glue, just wanted to let you know.
- de myname
Here is your glue and the UV light to go with it:
http://www.amazon.com/Adhesive-Blackligh...
- de srussianovcharka
myname, the repair job you did for your friend is a VERY POOR quality screen repair. Of course you will need to apply a special glue on the screen surface before attaching it to the glass. Otherwise you'll have air and dust trapped in between layers which is a cheap Android phones like.
- de Max
