washer does not finish drain cycle
My washer has started to stop during the drain cycle. It sounds like the pump is running. When this happens, many times the door will not unlock. I have to unplug and replug the electric cord. Sometimes it works, other times, I have to do that several times before the cycle is complete.
Is there some kind of filter in the drain line that could be getting clogged?
Es esta una buena pregunta?
11 comentarios
My old washer wasn't emptying properly so i got a new one but this is doing the same. It does a wash but doesn't empty properly. What can i do?
- de nicola willoughby
Hi @ nicola willoughby,
Have you checked that the drain that the washer's drain hose is placed into is not partially blocked, preventing full flow of drain water?
- de jayeff
How do i do that?
Where the washer's drain hose is inserted into a drain hole, remove the drain hose from the drain and then if you can pour some water into the drain and check that it flows away freely and doesn't build up and come back out
- de jayeff
No idea about washers only how to work them
Mostrar 6 comentarios más
