ipad is disabled, how to unlock it
there was a password on the ipad someone try to unlock it to many times and now it is disabled. how can I get back into it
Es esta una buena pregunta?
Tiffiney, best would be to restore the iPad from within iTunes. You can restore with any computer, but you will lose everything on the iPad, unless you use the computer you normally sync with. . You will have to download all of your purchased content again after you unlock the device. You will also have to use recovery mode. for more info on that check on here. Hope this helps, good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 6,525
1 comentario
Have you tried to restore it under iTunes on the computer that you normally use?
- de oldturkey03
