Where is the fuse panel located?
I can't find the fuse panel on my Dodge Caravan.
Es esta una buena pregunta?
Chad Fletcher, there should be two fuse box locations. One is under the dash on the driver's side. The other fuse box is under the hood, between the battery and the left fender. This fuse box contains many relays in addition to fuses. Be sure to replace the cover and ensure that it securely fastened to prevent dirt and moisture from getting into it. I attached a few images from the manual that might help you with your problem. Also, check this video, just in case. I hope this helps, good luck.
Fue útil esta respuesta?
I dont c no fuse box under the dash and radio has went out. Please tell me what to do.
Incorrect. On all 4th generation 2001-2007 GC and T&Cs there's a single fuse box under the hood near the battery. It's called the IPM.
There is no fuse for the radio though
Yes there is a radio fuse. It's 20 amp fuse #14 in the IPM. On the highline vans with the amp there's a separate fuse for the amplifier, 30 amp fuse #20.
i have no power to the starter relay
Dodge uses a bcm or fcm for most of there fuse and relay work there is only one fuse box most of the time and you wont necessarily find fuses for everything as may are lumped together however there is one fuse overlooked called the IOD. IOD stands for Ignition Off Draw and usually provides memory power to the BCM and security ECU as well as the radio, with it pulled the interior lights and power door locks won't operate.This fuse is a dealer installed item, IE the factory pulls it after testing so that the battery doesn't drain as fast while the vehicle is in transit to the dealer.Try replacing this fuse first .If this doesn't help a complete fuse panel replacement is a sure fix as these panels with the fcm (front control module) or bcm(body control module)can prove to be a rats nest of trouble with cascading problems. An occasional help is to remove the module on the end of the fuse panel usually next to the fender and clean the connectors looking for corrosion . This is usually a short term fix.R and R the fuse panel is your best and quickest fix. A lot of time can be wasted rewiring and cheating the panel. Sorry cant have a cheaper fix but Ive played with enough dodges to know that even though its an expensive fix in the long run its also the cheapest
Why want my van start I put a crank sensor can sensor starter computer
There is only one fuse box on the 2006 Dodge Grand Caravan. Its under the hood on the driver's side. Its called.an integrated power module or ipm for short. Do not waste your time under the dash.
El panel de fusibles en una caravan año 2000 se encuentra en la parte izquierda del motor (lado del chofer), una caja negra rectangular que dice FUSE & RELAY CENTER.
Google translate
The fuse panel in a 2000 caravan is on the left side of the motor (driver's side), a rectangular black box that says FUSE & RELAY CENTER.
Julian Bazan, 204merrick Check the attached links,instruction and guides, Good luck.
2001 to 2004 interior fuse panel location.
https://www.carcarekiosk.com/video/2001_...
2001 to 2004 engine compartment fuse panel location
Where the fuse for the speed limit
My van has the light on the L gear even if it's on park it won't start can you help me find out what's wrong with it
Ultimas 24 horas: 11
Ultimos 7 días: 92
Ultimos 30 días: 425
Todo El Tiempo: 373,000
21 comentarios
we also have a 2005 dodge caravan 2.4 and can't find the second fuse box... does it even exist? Our clock/radio/cd player doesn't work and when we start the car, all the interior lights turn on, turning off a few seconds later.. somethings wrong, and we can't figure it out.. anyone out there to help?
- de serrato's
I have a 2001 Dodge Caravan model month is 6 but yet it dosesn't have a Fuse Box under the steering column and cannot find the Fuse that I need in the main Fuse Box under the Hood. the Fuse I need is for the Interior Lights.
- de Feliciano
I need some help my power windows won't go up on my 03 grand caravan and can't seem to find the inside fuse box any thoughts.
- de davehiltab
fuse box in the 2003 is under the hood behind your battery
- de hbhutchins83
The 2001 Dodge Grand caravan has two fuse boxes ,the second is under dash on fire wall
- de Cory Astbury
Mostrar 16 comentarios más
