Saltar al contenido principal
The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
Preguntas 33 Ver todo
How do you remove lower steering column cover
The ignition key is stuck in the ignition. I've tried the key release with no luck. I need to remove lower steering column cover to see what's going on. How do you remove the lower cover?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
There is a key removal bypass underneath the keyhole to remove the key when this happens. I pulled up a video for you that shows you how to use it to remove the key.
https://www.youtube.com/watch?v=UNVbCakt...
Hope this helps!!
Cheers
Monte
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Dane Justice estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 23
Todo El Tiempo: 47
