System error (zoom) how do I fix it?
I don't know what happened, one day I turned on and it said that
Es esta una buena pregunta?
TRADUCCION:
No sé qué pasó, un día me encendí y decía que
Por favor aporta mas informacion
Fue útil esta respuesta?
@dani26140 The System Error (Zoom) message means the camera lens does not operate at all. This is usually because the lens area has been contaminated by dust, sand, etc. The damage can be sometimes be repaired by cleaning the camera lens area.
First I would remove the existing batteries and the memory card from the camera, wait one minute and then put the batteries and the memory card back and turn the camera on. If that does not work you could try a vacuum cleaner and apply some suction around the lens case. Some people swear by using a piece of paper around the lens area and move it around the gap to possibly dislodge anything stuck in there. To repair your lens etc. use the SM for this model Panasonic DMC FT3 DMC TS3 I only have an English version but I do hope it will work for you.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@dani26140 El mensaje de error del sistema (Zoom) significa que el objetivo de la cámara no funciona en absoluto. Esto suele deberse a que la zona de la lente se ha contaminado con polvo, arena, etc. A veces se puede reparar limpiando la zona del objetivo de la cámara.
Primero quitaría las pilas existentes y la tarjeta de memoria de la cámara, esperaría un minuto y luego volvería a poner las pilas y la tarjeta de memoria y encendería la cámara. Si eso no funciona, puede probar con una aspiradora y aplicar un poco de succión alrededor de la carcasa del objetivo. Algunas personas juran que el uso de un trozo de papel alrededor de la zona de la lente y moverlo alrededor de la brecha para posiblemente desalojar cualquier cosa pegada allí. Para reparar tu lente etc. usa el SM para este modelo Panasonic DMC FT3 DMC TS3 Solo tengo la version en ingles pero espero que te sirva.
Mientras trabajas en tu cámara, haz muchas fotos. Una vez que haya terminado con él, tomar esas fotos y crear una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 57
Todo El Tiempo: 130
