Saltar al contenido principal
lights on the cluster flicker when I try to start it it all goes dead
I have a question hopefully some one can help me figure this out ! 2007 Mitsubishi galant the ignition was ok till now now I try to start it the lights on the cluster flicker the when I try to start it it all goes dead .the battery is fully charged don’t know where to start !! Does anyone had that problem with the ignition and knows how to fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @michaelgiovanni
Looking at the images of the starting circuit and some of the cluster lights, it seems that the only common factor may be a faulty ignition switch.
Once the ignition is turned to the start position the starter motor should begin to turn over as it is basically direct wiring from the switch via the transmission switch to the starter.
(click on image)
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Michael Giovanni estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 32
