Device is not charging
Hi! I have problem with my Hero 6, It's not charging but It can be turned on by plugging a charger, without charger it does not
Es esta una buena pregunta?
Hello @johngilbert9992! Have you already tried another battery? If the battery is failed it might explain why it won't power on without a charger, also, what % does the battery show up as when the camera is plugged in, if any? Thanks! :>
Fue útil esta respuesta?
Hi! Yes, I tried changing the battery but nothing change, turns on only if I plug a charger even without a battery inside and its show electrical plug charging indicator i think ^^
@johngilbert9992 Ah ok no worries! Have you already tried factory resetting the GoPro? I think there might be a setting somewhere that sets it to only use mains power? Or i could be misremembering, I use GoPros a lot myself, but I use a Hero 9 not a Hero 6. Thanks!
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 65
