Why is my obd2 port not communicating with my ecu
My obd2 port not communicating with my ecu what should I do?
Es esta una buena pregunta?
@jasoncribb check your fuses. Commonly the OBD plug is fuse to the lighter plug. check the wiring harness for corrosion as well as fryed or loose wires. If everything checks out good then the issue is with your ECM
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 240
