Saltar al contenido principal
La Sony Cyber-shot DSC-H20 es una cámara superzoom económica de 10 megapíxeles con un rango de zoom óptico de 10x equivalente a 38-380 mm. La cámara tiene una pantalla LCD de 3 pulgadas y produce video HD de 720p.
Preguntas 6 Ver todo
Power button light is flashing but not booting up
I recently bought a used sony h20, which the seller told me supposedly still works but has a broken battery. I bought a new one but the problem remains: the green light on the power button and the light beside the lens flash once when i press the power or playback button, but then nothing else happens. I tried connecting the camera directly to an AC adapter as well as my computer, but still no luck. What could be the issue here?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@ejeeeee that is going to be a tough one. I suggest that you check the power circuitry. Of course this includes the battery contacts as well. This Sony Cyber ShotDSCH20 should help you with that task.
See if you find something that either looks odd or fails your test. You can always post pictures of what you are up against with your QUESTION.
Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
AJ. estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 41
Todo El Tiempo: 601
