Saltar al contenido principal
Lanzada en 2010, la Flip Mino HD es una videocámara de bolsillo con 4 GB y una hora de capacidad de grabación.
Preguntas 25 Ver todo
Red Light When Plugged In to Power
Hello there, My Flip MinoHD does not turn on when plugged in, the red light on the side of the lens flashes when plugged in, the red light is static when I press the record button, the flip does not get fully detected by windows. All help would be appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
A lot of the time on the Mino HD, it’s usually a tired battery due to the age of these. The issue with these is a dead battery will render it completely unusable. Tese days, most people opt to put it up for parts and see if they can at least sell it to get a few bucks out of them.
While Cisco no longer supports them, you can buy a 3rd party battery. However, it’s not always the best option with the age of these camcorders compared to the advancements in even a 3-4 year old smartphone, and standalone camcorders. If you insist on a standalone camcorder you’re usually better off buying a camcorder or point and shoot with AVCHD and MP4 options in many cases. That said, the smartphone in your pocket often is good enough for many as well so get a tripod mount for your phone and try to shoot with that if you have a lot of space (128GB minimum, 256GB+ recommended).
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks for your response, the camcorder is special to me so I wanted to fix it, I also love doing tech projects and experiments.
- de
Respuesta Más Útil
TechVid this could simply be a depleted battery. I suggest you start by replacing the battery. Here is the guide for it Flip MinoHD Battery Replacement Replacement batteries are available at places like this Re-evaluate once you have the battery replaced. If nothing else it will provide a known-well starting point for further troubleshooting.
Puntuación 1
4 comentarios:
@oldturkey03 I have just replaced the battery, so far I have a static red light when plugged in and when unplugged the light stays on. What does this mean?
- de
TechVid seems to be not finding the battery. Have you fully charged it?
- de
@oldturkey03 the camera was just a bit confused after not being turned on for a while.
- de
@TechVid it finally become unconfused?
- de
Añadir tu respuesta
TechVid estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 45
Ultimos 30 días: 144
Todo El Tiempo: 2,089
