Saltar al contenido principal
Guías de reparación para las cámaras Rollei y accesorios
Preguntas 4 Ver todo
How to clean the matt screen of a Rolleicord II?
I own an old Rolleicord II. It's matt screen is quite dirty, so I'd like to clean it. Can anyone help me how to do so?
My first approach would be to disassemble the camera until I can remove the matt screen, then clean it with isopropyl and a cotton stick. Is that sound?
Are there any problematic steps when disassembling, I have to be aware of?
Thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Is the inside of the screen dirty? You could take the camera apart though there are some risks to doing that. Firstly, I’d recommend grounding yourself and your work surface so as to be sure you don’t damage the camera with static. iFixit makes a great kit for grounding your workspace and yourself: Portable Anti-Static Mat
For the actual cleaning, isopropyl  should do the job, but be sure to let it fully dry before you reassemble the camera. A screen or optics cleaner could work too
Imagen de Portable Anti-Static Mat
Producto
$29.95
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I don't think grounding has any effect here, as there are no electronics in this old camera.
- de
Hello, I suggest you do the cleaning itself not with isopropyl, but with ECLIPSE Optic Cleaning Fluid by Photosol Inc. (you can also use cleaning pads sold by them, recommended). Isopropyl will leave the traces. Clean everything you can with a soft brush, then finish with the fluid. That way, you will have your screen as clean as it was when it left the factory.
Puntuación 0
1 comentario:
Thanks, this cleaning fluid looks good in general.
Not sure thou, if this old matt screen is already coated, i.e., if its necessary to use a special fluid for cleaning?
- de
For cleaning the matt screen, see the other answers.
Unmounting the matt screen
Simply screw off the following four screws:
Now, the frame holding the matt screen can be pulled out:
Puntuación 0
Añadir tu respuesta
Friedrich Wiemer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 276
