Saltar al contenido principal
The Zoom H6 Handy Recorder is a portable audio recorder with interchangeable mics and several built-in effects, and can also be used as an audio interface for computers and tablets.
Preguntas 20 Ver todo
How do I fix a broken micro USB port on my zoom h6?
So, my device fell off a table while connected to a usb cable. After that it stopped working. From the picture of the zoom H6 internal parts, it look like the micro USB port is soldered directly onto the motherboard. However, the company does not manufacture repair/replacement parts. This seems like a difficult fix to me personally, but it doesn’t look impossible. How would one fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi
The motherboard would have to be removed from the device so that the micro USB port can be accessed and unsoldered from the board and a replacement be resoldered in its place.
You would need smd soldering tools and expertise to perform the repair.
Here’s the ifixit Zoom H6 Handy Recorder Motherboard Replacement guide that will help you to remove the motherboard.
Here’s a zoomed in image of the connector taken from Step.11 of the guide. It is useful to see it because there are a lot a micro USB sockets available but they are not all the same. The main differences are whether they are the “through hole” or smd (surface mounted device) type and importantly where their mounting lugs are situated on the body of the connector as this can vary as to the location and even how many there are. The mounting lugs are soldered onto the board to give the socket mechanical strength and to take the strain away from the pin connections (which are standard) which carry the power and the data.
(click on image to enlarge for better viewing)
As can be seen from the image your particular connector will have 4 mounting lugs. Search on places such a Ebay (or digikey.com or mouser.com) for a micro USB female 5 pin smd (examples only to show the different mounting lug types) to hopefully find a connector where the mounting lug location matches what you have.
Here’s a video that shows how to remove/replace a smd USB connector. This is not for your board but the principle is the same.
If doing this yourself is too daunting, contact a reputable, professional mobile phone or electronics repair service and ask for a quote. If they say that they’re not familiar with your device tell them about the the ifixit repair guide. Once they can access the port the repair would be familiar to them and they have the necessary tools and skills to do it. They may even have a compatible replacement connector as well.
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
tnima95 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 41
Todo El Tiempo: 1,616
