Saltar al contenido principal
Repair manuals and information for the Microsoft Surface book line of laptops.
Preguntas 207 Ver todo
Resetting/replacing corrupted UEFI Bios?
Hi there
Recently my surface book downloaded an automatic firmware update which bricked my device. Microsoft are denying responsibilty so I am looking into alternative ways of fixing it (there’s a whole thread about the issue linked here, several others have the exact same issue)
So I have two questions:
  1. Would it be possible to reset the bios by unplugging the main battery inside? (Similar to removing a cmos battery on a desktop motherboard)
  2. If the above answer is no, or a reset does not work - which chip contains the bios on the surface book (As I saw there were several flash chips on the teardown guide) and where could I get a suitable replacement?
Thank you in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario
Same happened to my surface laptop 3. Microsoft isn't refusing the fix it. They want 400$. And that was the last time I ever bought a surface product.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Removing the battery for a few minutes should definetely reset it.
You could also try the ‘‘hold volume up+press power button’’ before you start digging for the battery.
With either one of these you should be good to re-configure your bios.
Fue útil esta respuesta?
Puntuación 1
11 comentarios:
Thanks for the answer!
I've tried the button combination - does not work unfortunately (this all happened after a firmware update, so I suspect the bios could be corrupt).
I'll open it up, unplug the battery and update you on how it goes!
- de
@rtxd I hope you fix it nice and ez :)
- de
how did it go?
- de
Not great to be honest.
I managed to take it apart (busted a few components in the process, but I expected this).
I unplugged the battery but plugging it back in after some time did not change the outcome.
After a bit of research, it turns out that the firmware update caused the bios data on the eeprom chip to go bad. Which means doing a 'hard reset' to the bios won't change anything, since the back-up (on the eeprom) is also shot.
I then attempted to reprogram the bios chip myself manually, but it was too difficult to get to the chip on the motherboard since it is a surface mount component.
So in other words - Microsoft pushed a firmware update that bricked my device....
- de
Were you able to get it working again? I think I am facing the same issue you.
- de
Mostrar 6 comentarios más
Añadir tu respuesta
RT-XD estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 62
Ultimos 30 días: 296
Todo El Tiempo: 12,273
