Saltar al contenido principal
El sistema operativo de Apple para sus computadoras portátiles y de escritorio Mac.
Preguntas 72 Ver todo
Trying to install El Capitan on iMac
My MacBook is running Mojave and I need to instal El Capitan on my iMac (what was on it before I needed to replace a bad hard drive).
I can’t get it to download using my MacBook through legitimate Apple sources.
HELP! That link Aaron provided is from Apple and since I am running Mojave I can’t download it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios:
So if anyone had this same problem and could help me before I pull ALL of my hair out that would be greatly appreciated!
- de
Same here, any luck?
- de
did you get to the bottom of this? im in exactly the same situation
- de
Agregar un comentario
1 Respuesta
Depending on the age of your iMac you should be able to install your new SSD into your system and then run the Internet restore using the start up keys: Command (⌘) & R keys
Reference: About macOS Recovery
To gain access to the older macOS’s use the startup keys Shift & Option-⌘ & R keys
Reference: Reinstall from macOS Recovery
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
amanda819 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 524
