Saltar al contenido principal
The Discovery Series I was introduced into the United Kingdom in October 1989.
Preguntas 3 Ver todo
Front right brake locks up
When driving and braking after about 15 minutes the car slows down and only the right tire locks up the car won't move in drive and the brakes are hard to push down. But once we bleed the brakes on that side it unlocks and it's good to go. Already replaced master cylinder, brake booster, brake fluid reservoir, pads and rotors, caliper on right side and brake line. Have no idea what to try next
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Hi there!
Does yours have ABS (Anti-lock braking system)? If so it could be that there is something really wrong with either the ABS system control. So try disabling/unplugging the power for it.
Let me know if this helps or you don’t have ABS.
Fue útil esta respuesta?
Puntuación 0
Abs module and abs sensor, these are you next possible culprits. I'll take apart a module and post pictures for you, the sensors will need to be replaced. If you disconnect the abs module it will brake harder on one side more, typically the right hand side, your vehicle will most likely pull right when you brake hard. This will heat up your brake fluid quicker and reduce the life on your master cylinder and booster pump, also unevenly wear your brakes. But yes pulling the wiring harness out of the abs module will disable the abs to see if it is the problem.
Puntuación 0
Añadir tu respuesta
Jamie Barker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 241
