Saltar al contenido principal
Los altavoces de agua danzante son altavoces de computadora que cuentan con chorros de agua iluminados por luces LED multicolores brillantes.
Preguntas 9 Ver todo
Sound works fine, water won’t shoot up.
I bought a Sylvania water dancing speaker a while ago. Sometimes i have the tendency to leave my speaker on while i run a quick errand. I once left it on, thinking i wouldn’t take long — i was wrong. It stayed powered on several hours without any music playing, so when i got back i noticed the water wasn’t shooting up. Usually all i had to do was power off, & power back on to get the water to work fine again. This time it didn’t, the sound works fine. It lights up, but no water goes up.. Yet it’s still got water in it. Same amount as when i bought it. Can i easily fix this at home? Thanks!
Es esta una buena pregunta?
Puntuación 2
3 comentarios
What my water not coming up wen i play music
- de
Have soundproof dancing water tower speaker, sounds good but the water doesn't shoot out to the music what is wrong?
- de
Help how do i take it apart.to refill water
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Open it up and use a multimeter to test for continuity of the wiring and see if you may have burned the motor out. Here's how to do surgery on it:
Water Dancing Speakers Refill
Fue útil esta respuesta?
Puntuación 6
Respuesta Más Útil
I bought a Sound Logic Wireless Dancing Water Tower Speaker and i noticed the water didn't shoot up anymore what can I do to fix it at home?
Puntuación 8
2 comentarios:
I have the sameone and the water stopped shooting up. Did you ever figure out what was wrong
- de
same here so I took it apart and everything was naked just fine the motor was no longer turning so now I'm trying to find where I might order a new little motor which is really quite easy to wire into place , just two little sodering spots to connect it but i just started looking for the part
- de
My soundlogic BTS-600 won't stay on what's wrong with it I have to hold button for it to stay on
Puntuación 0
Añadir tu respuesta
Marely estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 110
Todo El Tiempo: 10,628
