Saltar al contenido principal
La carrocería del modelo de segunda generación tiene una pista más ancha y una distancia entre ejes más larga que el anterior MDX. El motor fue actualizado a un V6 de 3,7 litros afinado para 300 hp. Acelera de 0-60 mph en 6.5 segundos, uno de los motores más potentes que Honda ha producido hasta la fecha.
Preguntas 11 Ver todo
Why is my idiot light on a 2007 Acura DMC saying "Battery not charging
I have a 2007 Acura DMX. Today (11/21/2017) I took the car out in a heavy rain. Eventually, I lost power. Pulled over side of the road, waited awhile and started car up again. Idiot light came on to say "Battery not charging" but I could run the car. However, power steering was totally gone and had great difficulty in turning the wheel in either direction. I thought everything had gotten soaked from the heavy rain. It is now 8 hours later. Car is parked in a warm garage in my house. Turned up car again. Again, idiot light came on, "Battery not charging". What should I do in this situation. Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@expofrosty double check your belts. Since you have no power steering and your "Battery not charging" could be a sign of a broken alternator belt. If the belt is okay you will have to consider to get your alternator checked (try places like Autozone or your dealer) with a worst case scenario of replacing your alternator. Check on here for that.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Bob FitzPatrick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 22
Todo El Tiempo: 176
