Can I use the pump from a 700r4 in 4l60e
can i use the pump from a 700r4 in a 4l60e
Es esta una buena pregunta?
It depends. If they have the same part number, Yes. If not if they look the same in every way shape and form you can give it a shot. There is the chance that you break something and then your screwed but if everything looks the same besides model number you can give it a shot if you want to take the risk.
Hope this helps! Good luck fixing!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 953
Dont have money right now to replace New and had a pump from a 700r4. But the pump go's down so far then stops will not seat all the way down any ideas?
- de John Doe
