Red light is blinking
My Polaroid SNAP wont print out pictures. The 3rd red light is blinking. Do I need a SD card that way it can work? Someone please answer ASAP.
Es esta una buena pregunta?
@anonymous__ ,Anonymous, Find below links to troubleshoot your Polaroid SNAP, If the camera is still under warranty and problem persist after using the trouble shooting guide link #1 and your manual link#2, then use link #3 for contacting Polaroid support and warranty. Good luck.
Fue útil esta respuesta?
No you do not need an SD card to take pictures. You can either have the film OR the SD card. Or both! The red light is just telling you its missing whatever the red light is flashing in.
I think I know how to fix the problem. The camera is very picky depending on how you put the film in make sure the part that says sink zero ink is facing downwards and the blank part should be facing towards you.
I had this same problem. It was an error with the paper, I had to keep playing with it a little. I bent the stack of paper a little the other way to straighten it out as it was bent just slightly and then i pressed hard on the back when I closed it. I think that helped get the paper in place…
Ultimas 24 horas: 12
Ultimos 7 días: 44
Ultimos 30 días: 160
Todo El Tiempo: 29,578
3 comentarios
I have this problem too, how did you solve it?
- de Dani Ceparano
i also have this problem. how am i supposed to take pictures?
- de Trinity Akins
Me too ,how do you fix it?
- de Wolfie_ gameZ
