Saltar al contenido principal
The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
Preguntas 33 Ver todo
Why is my car not starting and showing code 89
My 2012 chevrolet cruze is giving problem to start as if my battery if flat bt all the lights and hooter are working properly.When i turn the key the alternator turns a little bit and gives me code 89.When i jump start the car it starts without any problem.my battery was serviced and the car could start atleast 4 times after that but then it started with the problem the next day
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
I also have similar problem.
Error code 89, sound is loud.
What could be the problem?
- de
Yes, similar the noice of the engine become in side the sound system...through the speakers.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi,
Check the output from the alternator.
Use a DMM (Digital Multimeter _ Voltmeter function) and connect it across the battery terminals with the engine running, (Be careful when you do this as the engine is running!)
The Voltmeter should read between 13.8-14.4V DC. If it is less than 13.8V DC then the alternator is not charging the battery and it will slowly go flat.
If this is the case take your car to an auto electrician to get the alternator checked.
Fue útil esta respuesta?
Puntuación 2
This some how related to the steeeing lock, shutdown the car and press the start button without break (or open the contact if its not with a keyless start) and then unlock the steering then move a lttle left or right the start the car it will start normaly.. If it works dont ask me why coz I dont know, I just discover this solution by myself
Puntuación 1
1 comentario:
Thermostat issues
- de
Añadir tu respuesta
Joseph cafu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 119
Todo El Tiempo: 46,105
