Saltar al contenido principal
Guides and repair information for 49cc gas-powered scooters.
Preguntas 25 Ver todo
ignition key wires a different color than new ones
Purchased a new 4 wire Ignition key Switch for my 49cc gas scooter and the colrs of the wires do not match the old ones which are Red, Orange, Yellow and Green. The new key Ignition Switch wiring are -Red, Black, White-Red and White Black. How do I know where each wire goes.
Attn; The on-line store which I purchased from advertised the original colors but sent me the different colors of Black, Red, White-Black, White-Red.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Respuesta Más Útil
First thing I would do: complain at the online store. If they make advertisement with the original colors, but your delivered part has different ones it can be difficult to connect it. Maybe they already had this problem and have a solution for it.
But if they can't (or don't want to) help you: Check which cabels are connected when the switches are turned to "ON" position (and maybe a second time when it's in "OFF", but probably there will be no connections). Then you can replace a pair from the old one with a pair of the new one.
Fue útil esta respuesta?
Puntuación 1
Hi do you have an email I might be able to help if you have ignition with you ross-135@hotmail.com
Puntuación 0
Hi email me ross-135@hotmail.com
Puntuación 0
i gotten a ignition key switch with the color wires as followed yellow with green stripe red black and one that goes to solenoid now i got a new volt regulator with new charge coil but on the volt reg, the color wires are yellow red green pink how to hook them up along with ignition coil its a predator engine anything help cause i cant get spark nothing i adjusted valves several times align with adjusting coil pack several ways with a card feeler gauge etc
Puntuación 0
Añadir tu respuesta
Angelrey Feliciano estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 36
Todo El Tiempo: 2,971
